Go Back   Automotive Forums Car Chat > Toyota > Scion xA/bB/xB/tC
Old 05-08-2010, 12:10 PM
equalizir equalizir is offline
2005 scion xb water pump gasket question?
Hi guys,
i need help with my other car and i dont know where else to get adivice. i have a 2005 scion xb and im in the process of putting in a new water pump. i bought a new water pump at autozone and i was checking out the paper gasket that came with it i accidentally broke it. I know it sounds crazy but it was so brittle that it just split in two.
so when i pulled the old water pump out it had a metal gasket. my question is can i reuse the used metal gasket? I thought if i did reuse the metal gasket that i could use some permatex ultra 2 sealant on each side of it to make sure there was no leaks. what do u guys think?
Old 06-02-2010, 01:55 AM
robertwilliam03 robertwilliam03 is offline
Re: 2005 scion xb water pump gasket question?
Hai guys,
WATER PUMP, NEW -- Includes 1 paper gasket; Features a high flow design that provides long lasting and efficient cooling; Designed for OE fit and performance; Factory lubricated for long life; The precision ground shaft and hub accept OE fan clutches perfectly; Its OE quality forged housing is specially formed to ensure maximum coolant flow; Precision built and balanced with its pressed on impeller that increases water flow; The unique no-sealant required gasket makes installation fast, easy and leak-free; Its unitized seal protects bearings that provides long life and leak free performance;
