Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 05-08-2010, 11:36 AM
534BC 534BC is offline
97 bogs when gas is pushed
Hi, I have a 97 that acts like it is running out of fuel when throttle is pushed. The fuel pressure at the injectors remains 38-40 when pushed (30 when I let off the throttle)
It acts like a car runing out of fuel , if it's babied it will run fine or if it is ran at about 3/4 throttle it runs strong. Many times though at WOT it bogs down for many seconds. If you let off then floor it again it might run perfect the seciond time it is floored. It will run well over 100 mph with 40 psi pressure even whn acting up.
My scanner is very basic and can't see a lot of info , the only thing I notice is the fuel trim is generally at +15-25%. I see nothing out of the ordinary cold or hot. It'll act up in closed loop or open loop.
Any ideas on how to further diag this? (or what may be wrong with?)
Thanks.
Old 05-08-2010, 01:17 PM
mcmalloy mcmalloy is offline
Re: 97 bogs when gas is pushed
Check what the specs are for fuel pressure, most fuel injected engines run around 50psi
Old 05-08-2010, 03:10 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Since the fuel trim is unusually high, check for a vacuum leak. Also clean the MAF sensor with CRC MAF Cleaner. If the MAF wire is dirty it will not read accurately.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 05-09-2010, 07:36 AM
Thanks for responses. The book said 35-40 psi. I will clean the maf and check for vac leaks (I don't think there are any)
Old 05-10-2010, 04:23 PM
It was the MAF , it had a bunch of fuzz on it. I was going to clean it last week , but didn't have any safety torx bits. I cleaned it today and it fixed it up so far. Thanks.
Old 05-11-2010, 10:33 AM
Glad to hear it was an easy fix. You can usually clean it off without having to remove it from the MAF housing. I just spray some compressed air and then some MAF Cleaner at it with the hose and top of the airbox still attached to the housing.
