Old 05-07-2010, 05:15 PM
mikeso_81 mikeso_81 is offline
Air Conditioning Help
Hi,
I have a 2001 Pontiac Grand Prix GT and I just went to the local shop to have my ac charged. Well, a week later the system is blowing warm again. Obviously I have a leak somewhere. I wanted to pump some dye into the system to determine the leak but my question is how many cans of 134a (w/dye) should I pump into the system? I have a pressure kit but want to ensure I do not put too much/too little into the system. What is the proper pressure range? Do I put enough to charge the whole system back? I just don't want to pay another $100 bucks for the shop to pump $20.00 worth of dye into the system.
Thx
Old 05-07-2010, 06:18 PM
brcidd's Avatar
brcidd brcidd is offline
Re: Air Conditioning Help
compressor shaft seal is number one leak location, compressor belly is number two....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 05-10-2010, 01:18 PM
What are the proper specs? How much freon/oil do I put into the system? Do I fully recharge the system or should I just put a couple pounds freon dye into the system?
Old 05-10-2010, 07:43 PM
BNaylor's Avatar
BNaylor BNaylor is offline
On a total system evacuation you should use 2.25 lbs of R134a refrigerant. Double check the data label located under the hood. It varies with the PAG 150 oil and what A/C component is removed or replaced. You can get PAG 150 oil with dye in it.
The most important part is rent a electric vacuum pump before recharging the system and pull vacuum on the system to 27-28 hg for at least 30 or up to 60 minutes.
Timeslip 08/12/06
AF Community Guidelines
Old 05-10-2010, 08:48 PM
doctorhrdware doctorhrdware is offline
When I repaired refrigerated waterbaths. After replacing the bad parts, I would pull the system down to the lowest vacuum I could get. Close the system off and leave it over night. Then check it the next day, and if the vacuum dropped I would check all the brazing that I did to make sure that I did a good job, if not I would re-braze the bad weld that I did.
Old 05-17-2010, 06:50 PM
I bought a vaccum pump and gauges and I'm ready to go. When I evacuate the system via the vaccum pump, does that also purge all of the pag oil from the system?
Old 05-17-2010, 07:55 PM
brcidd's Avatar
No, the oil does not come out of the system when pulling a vacuum.
'99 GMC Yukon
Old 05-18-2010, 03:44 PM
I just found out that my ac pump is bad. Go figure. When I replace the compressor do I buy pag oil in the air compressed can and or in a regular screw top bottle? As well, what grade of pag oil do I buy (46/100/150?) Thx
Old 05-19-2010, 11:28 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
If you're buying a new or reman compressor, you need to buy the pour-in PAG-150 oil. The oil needs to be added to the compressor itself, then the compressor needs to be hand rotated 10-15 revolutions (read the instructions that come with the replacement compressor for suggested amt) to distribute the oil prior to hooking it up. Failure to do so will result in compressor failure.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 05-19-2010, 01:58 PM
rkvons's Avatar
rkvons rkvons is offline
If you haven't lost any oil from your system, you're supposed to carefully remove the old compressor and pour out and capture the oil that is in it. You determine how much oil this is and then put that exact same amount of fresh oil into the new compressor. If you've lost oil through a leak, all bets are off.
