Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 05-07-2010, 11:49 AM
VoXGM VoXGM is offline
Help :(
First off i dont know much about cars. I guess because im of the female gender, as most people would say. Anywho, i need some help on is to how much air i need in my tires. I have 22's on my ranger with kumho 265/35 R22 tires. The tire says 50 max psi. And i know i dont need them max. Right now they have about 32 psi. How much would be perfect? ^_^
Old 05-08-2010, 05:43 PM
tjr1000 tjr1000 is offline
Re: Help :(
I believe the recommended pressure is usually posted on the inside of the driver side door. You can find it on the end when the door is open. 32 pounds is probably about right.
Old 06-30-2010, 02:56 PM
cm1 cm1 is offline
Re: Help :(
Hi.
I don't like to run tires much more then 15psi below tire maufactures spec. tire will wear out faster.
Thats what happened in the 90's with Firestone tire rating 50psi ford recommended 28psi BAD
hope this helps
Old 07-06-2010, 07:10 PM
Eliut Eliut is offline
Re: Help :(
you have after market tires on this vehicle. the decal on the vehicle will specify the correct tire psi to the tire size. I would maintain the psi at 50 if that is what is on the side of the tire
Old 02-12-2011, 04:00 AM
badinten badinten is offline
Re: Help :(
well looks like none of this info so far will really help you being as the factory thinks you have the tires they put on it. i would say about 40 psi on the tire set up you have 32 will work but dont just go by the door jam factory sticker unless you have factory style tires
