Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 05-06-2010, 06:26 PM
jponce jponce is offline
help please!
my dad got a delta 88 royale 1981.. 4.3 with about 60,000 miles on it.. he stored the car for a while (couple of years) and just recently took it out.. he wants to sell it but it developed a lil prob since he took it out.. it got a coolant leak now.. looks like a good amount of coolant is leaking from the water outlet. the left side of the outlet to be exact.. kinda seems like its coming from the bolt on that side.. but was wondering if any1 has had similar situations and possible things it could be?
Old 05-06-2010, 06:46 PM
maxwedge maxwedge is offline
A990 racer
Re: help please!
4.3? Are you sure this is not a 307 8 cyl. Olds. if so the intake gaskets were a common leak area, as was the 260 Engine or 4.3
Old 05-06-2010, 07:02 PM
Re: help please!
i thought it was a 307 myself.. but my dad re-insured me that it was a 260..
Old 05-07-2010, 07:53 AM
A990 racer
Re: help please!
They look the same and have the same issues, press. test the cooling system for a better diagnosis.
Old 05-08-2010, 11:05 AM
Re: help please!
what should the temp for these be at?? the delt stays at 180 or soo when warm.. is that a little to high for these??
Old 05-08-2010, 12:28 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: help please!
No. You should have a 195 deg thermostat in that, meaning that the minumum operating temp is 195.
But chances are you have a 180 deg stat. So long as it is not s computer-controlled car, 180 is fine. But lower temps are not better. A warmer engine, (195-220 deg) operates more efficiently and with less wear than lower temps.
As for the leak.... it may just be the thermostat housing gasket is gone. Easy fix.
