Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 05-06-2010, 03:52 PM
Paul Buxe's Avatar
Paul Buxe Paul Buxe is offline
Fuel Injection to carb fuel pump??
I have a dumb question, is there any problem using the Bosch fuel injection pump when switching to a carb? I would not have a return fuel line I guess, so is there any possibility of damaging the Bosch pump if its dead headed without a return line? I would add a fuel pressure regulator of course to get the pressure down to carb pressure requirements.
Thoughts?
Paul
Paul Buxe
Panoz GTRO-0042 LS2 gone but not forgotten
Miata Chump Car
Mustang GT
Porsche Boxter (wife's ride)
Chev Suburban trailer hauler
Factory 5 Cobra Roadster, 392 stroker
You have to grow older, but you don't have to grow up
Old 05-06-2010, 04:28 PM
NZGTRA17 NZGTRA17 is offline
Re: Fuel Injection to carb fuel pump??
Thoughts?
Paul
Didnt try this Paul but expect it would be to high a pressure and yes would most likely kill the pump.
I used a Carter 100 GPH 7psi pump, the filter that was in the car with the injection and added a regulator up front. I have used these Carter pumps before and they have proved to be very reiable especially given thier very resonable price. Dont be fooled into buying an expensive brand name pump. There are quite a few unreliable "lemon" pumps out there...............
Kel M
Panoz GTRA #17
New Zealand
Old 05-06-2010, 08:45 PM
jmimac351's Avatar
jmimac351 jmimac351 is offline
Paul, Aeromotive makes a regulator that is specifically designed to allow a carb to be used with an EFI pump. Bob Gassie and I are using this regulator on our cars and it works great with the Bosch pump. Leave the fuel lines in there as they are and just plumb this in. It's not cheap but it makes this part of the conversion simple.
http://aeromotiveinc.com/products-pa...ass-regulator/
Jim McGovern
~ Building 289 Lemans Replica
~ '92 Mustang Coupe: 347ci / Carb
Pictures
Old 05-06-2010, 10:12 PM
Paul Buxe's Avatar
Thanks guys, I was worried that dead heading the stock pump was a bad idea. Thanks
Paul
Paul Buxe
Miata Chump Car
Mustang GT
Old 05-10-2010, 07:12 PM
Panoz26's Avatar
Panoz26 Panoz26 is offline
Paul, I purchased a new Hoilley for my Carb Setup - FWIW.
Devin - (aka Panoz26)
Formally WC Car # 26, Red
Now = WC-GT2 # 211, Black
Old 05-16-2010, 12:07 AM
boothkc boothkc is offline
Yep pressure will be too high and it's an expensive pump to replace in the future. We used a Holley electric pump and 650 carb, Performer manifold, MSD6 and MSD distributor and regulator from a GTS....all runs great finally.
Basically copied the GTS set up and added 351W Aluminum heads (had an old set) to the Explorer engine. Runs good. I use this car for friends to mess around at the track on track days. Limited the rpm to 5200 to try to keep things together for a while. Would be great fun with a 7000 rpm small block Ford. Would give the GTS a run for its money.
Kevin
Old 05-16-2010, 02:13 PM
Craig245's Avatar
Craig245 Craig245 is offline
Paul
Hi Paul, I have a new in the box Aeromotive regulator that I bought for using the Bosch pump with a carburetor. I think I have this one, http://www.summitracing.com/parts/AEI-13202/
but it may be this one,
http://www.summitracing.com/parts/AEI-13109/
At any rate I can check tomorrow and will sell it to you for 1/2 price, if you are interested.
Craig Wright
[email protected]
Craig Wright
PGTRA #21
'05 Ford GT
'65 XKE (newest addition)
Old 05-17-2010, 09:18 AM
eric1h eric1h is offline
I went with the Hollet Blue pump. A fuel injection pump puts out way to much pressure and without a return line it will put too much pressure on the pump and burn it out quickly.
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
Old 05-17-2010, 03:05 PM
Paul Buxe's Avatar
Craig
Rats, I already ordered and got a fuel regulator, I wish I had checked the forum again would have saved me some money.
Thanks for the offer.
Paul Buxe
Miata Chump Car
Mustang GT
Old 05-17-2010, 04:14 PM
Gatorac's Avatar
Gatorac Gatorac is offline
Craig Wright
[email protected]
Double check wich one it is and let me know. I may be interested.
Have Fun
Jim Pomroy
96 Miata track car.
2012 Camaro SS.
Backdraft Racing Cobra #930
92 Miata "LemonDrop"
Saturn V Rocket Miata Crapcan #81
99 Miata daily driver.
Old 05-17-2010, 06:55 PM
jmimac351's Avatar
Eric, the GT-RA cars have a return line so using the proper regulator with the Bosch pump is pretty easy. I''m hoping that it may even keep the fuel cooler since it's able to cycle through easily.
Jim McGovern
Pictures
Old 05-19-2010, 03:08 PM
yeah the WC's have a return line as well. And yes the lower pressures will keep the fuel cooler i bet!
Old 05-19-2010, 04:11 PM
Craig245's Avatar
Hi Jim,
The one I have is 13202, in the original box, never opened
here is the link http://www.summitracing.com/parts/AEI-13202/.
Summit price $159 I'll sell it for $70 plus $10 for shipping ups ground.If you want it quicker I can do second day air for about $30.
Craig
Craig Wright
PGTRA #21
'05 Ford GT
Old 11-12-2010, 03:28 PM
Blue Streak 21's Avatar
Blue Streak 21 Blue Streak 21 is offline
Craig;
Do you still have the Aeromotive regulator? I'd be interested in buying it from you.
PM me at [email protected]
Thanks.
Jerry
Hi Jim,
Craig
Jerry
1999 Panoz GT-RA
