Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 05-02-2003, 06:39 PM
vang's Avatar
vang vang is offline
17's on civic
this probally has been brought up on a few occasions but i cant find it so here goes.....
17 inch rims on a 91 civic hatchback?
Does it scrape when turning?
Does it rub against the car when hitting a bumb?
Any other problems with 17's on a 91 civic?
Old 05-05-2003, 11:08 AM
Cy@tirerack Cy@tirerack is offline
As long as the wheels are of the proper offset (38mm to 45 mm is the offset range of the 17" wheels we offer) and you run 205/40-17 you'll be fine. This assuming the car has not been lowered.
We have not test fitted 205/40-17's on a lowered car. In order to check clearance on a lowered car I would recommend searching this forum, the web etc to see what other Civic owners with lowered cars have run.
Old 06-20-2003, 03:49 AM
preludepride preludepride is offline
my lude'
ive got a question relating that about my 1993 honda prelud...
i want to get 205/40-17 with a EiBACH pro-kit and shocks...
am i gonna have a problem with wear,handling,can i race,etc.what about the speedometer...with i need to re-evaluate it or what?
any help or suggestions would be great
preludepride
How to take out a rear side window from a 96 honda civic Danthony_20 '96-'00 Civic 1 11-05-2009 11:38 PM
94 Civic with constant high pitch humming in front end.... lizshouse88 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 07-19-2009 06:49 PM
Civic Hybrid Cars-- '06+ Civic 0 05-04-2009 08:30 AM
96 Civic HX o2 Sensor Replacement.... shvd98z24 '96-'00 Civic 3 03-30-2009 09:49 PM
h23 swap 4th gen civic? 92lude91dx '88 - '91 Civic | CRX | Wagon | Shuttlee 4 03-16-2009 12:43 PM
