Old 05-05-2010, 08:17 PM
Forscythe87 Forscythe87 is offline
Guys I really need your help!
So today my car wouldnt start at all! I turned the key and got nothing! Took the car to Autozone for testing, my battery was a little low but everything checked out.
Had engine codes that got pulled today and I have a P0442 and a P0401. Now I have had a P0442 before but it went away and now its back and im smelling fuel near my fuel rail. Not sure if it was the EGR causing this smell or not.
With time ive become pretty skilled at fixing things on my cars but now these problems have me lost!
I did my LIM without pulling my injectors out. Is there supposed to be a seal where the fuel lines meet the fuel rail? Im asking because perhaps I need a new one there after disassembling it a year or so ago.
1998 Chevy Lumina LS 3.1L 126K Miles
Old 05-06-2010, 02:55 PM
maxwedge maxwedge is offline
A990 racer
Re: Guys I really need your help!
Didn't start? How did you get it to AZ? Cranked or no crank? If you smell fuel, you should be able to track the source.
Old 05-06-2010, 04:40 PM
No crank. Power in car turns on but wouldn't turn over. I gave it a talking to and it started after a few tries. I can smell it in the fuel rail, egr valve area but can't pinpoint it. An tips?
Mozilla/5.0 (iPhone; U; CPU iPhone OS 3_1_3 like Mac OS X; en-us) AppleWebKit/528.18 (KHTML, like Gecko) Version/4.0 Mobile/7E18 Safari/528.16
Old 05-06-2010, 05:00 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Try talking to it some more, maybe it will fix itself..
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 05-06-2010, 06:49 PM
A990 racer
Check the battery cables and terminals for loose or corroded connections, the egr cannot cause fuel leaks or fuel issues.
Old 05-13-2010, 08:00 PM
kevinb70 kevinb70 is offline
Send a message via AIM to kevinb70 Send a message via Yahoo to kevinb70
442 code = you make sure your gas cap is on tight? 3 clicks.
401 egr code. DONT REPLACE THE EGR.
get new throttle body gasket, a tomco kleen-screen egr gasket (+ the plain lower egr gasket) couple cans of throttle body cleaner, wire hangar or pipe cleaners (or both) maybe small brass brush
remove egr, clean it up, remove the throttle body, and clean the air passage between the throttle body and egr. clean throttle body. suggest not removing the iac. hit it with TB cleaner tho.
remove throttle body butterfly (torx bolts i think) clean thoroughly with throttle body cleaner.
make sure flexable egr tube isnt clogged
dont attempt to clean out the inside of the uppper intake manifold (big port) its a useless effort... just clean the small egr passage in the upper intake manifold
might hit the iac shaft with some wd40 or other light lube
Old 05-13-2010, 08:21 PM
jd-autotech jd-autotech is offline
check the vacuum hose to the fuel pressure regulator if there is any fuel in the hose at all even a drop the regulator is bad
Old 05-13-2010, 11:16 PM
Thanks for the EGR info. Will give that a try!
As for my gas cap. I replace it and its on tight. I start school in august and want to knock all these probs out now .
Old 05-16-2010, 03:40 AM
Bearwulf's Avatar
Bearwulf Bearwulf is offline
Instead of removing TB butterfly, get old toothbrush & tb cleaner & brush butterfly plate after hitting w/tb cleaner. Too easy to damage or loose screws.
Bearwulf, the "howling Grizzly" of the north.
MONOTONY is the worst driving hazard, so SHUT-UP when I'm driving.
97-Lumina LS
1891Argentine 7.65 with scope!
