Old 05-05-2010, 03:36 PM
flashlight flashlight is offline
Radiator Drain Plug
So here's the problem I currently have. The part of the radiator drain plug that allows you to tighten or loosen it has broken off. There is still part of the plug in the radiator which is a good thing. What I'd like are any ideas on how I can go about removing this so that I can install a new one. Please help me. Thanks.
Old 05-05-2010, 04:36 PM
Rooy Rooy is offline
Re: Radiator Drain Plug
An EZ-Out (screw extractor) might work.
Old 05-06-2010, 02:54 AM
Metro Mighty Mouse's Avatar
Metro Mighty Mouse Metro Mighty Mouse is offline
A dremel style tool with the right bit can cut a slot so you can use a screwdriver to remove the plug.
Old 05-06-2010, 06:27 AM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
As long as it does not leak, leave it. Use the lower rad hose to drain.
Old 05-06-2010, 08:13 PM
Thanks for the help. Used a drill bit to make the initial hole and then a screw extractor to remove the remainder of the plug. Just wish the weather had been better and it would have made for a perfect night.
