Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 04-15-2010, 06:51 PM
nlghtcrawler nlghtcrawler is offline
Send a message via AIM to nlghtcrawler Send a message via MSN to nlghtcrawler Send a message via Yahoo to nlghtcrawler
2005 Camry doesn't idle right
Wow, i was going to start a new post on this, im having the same problem on my 2005 Toyota Camry LE 4 cylinder. and it has this exact same problem, i cant seem to figure out the problem.
I made a video of what its exactly doing:
http://www.youtube.com/watch?v=uEAW4RD4ZRg
Old 04-17-2010, 01:48 PM
So my problem seemed to have gotten worse now when I start it in the morning it idles really rough then dies. When I start it again it runs fine for the rest of the day. Any ideas?
Mozilla/5.0 (Linux; U; Android 1.5; en-us; A6277 Build/CUPCAKE) AppleWebKit/528.5+ (KHTML, like Gecko) Version/3.1.2 Mobile Safari/525.20.1
Old 04-27-2010, 11:43 PM
Bump
Anyone have any ideas?
Old 04-28-2010, 09:08 AM
Mike Gerber Mike Gerber is offline
AF -Advisor
1. Clean the throttle body, paying particular attention to spraying the cleaner liberally down in to the square or diamond shaped port in the base of the throttle body, That port leads to the idle air control valve, where your problem may exist. Let the cleaner soak down there while you go on to clean the rest of the throttle body.
2. If cleaning the throttle body doesn't hlep the problem, I would next test the engine coolant temperature sensor. To do this you will need a digital volt/ohmeter and the specs from any manual. If you don't have a manual you can download one for free at the top of this forum's hime page.
Mike
Old 05-02-2010, 02:16 AM
ok this might sound like a stupid question, as i mentioned before my car is a 2005 (gen 5 i think) not the same as the original poster, is there anything different i need to do? Also is it best to clean the TB while its on or off the car, and if i need to take it off is there anything special i need to do while putting it back on?
(ps. the symptoms have gotten worse and it dies on the first start of the day and i have to start it twice and sometimes at stoplights it has a rough idle right before i take off)
Old 05-03-2010, 04:39 PM
DrJones876 DrJones876 is offline
Sounds like similar symptoms that I had with my 95 Camry. I changed the coolant sensor and it fixed my problem.
Old 05-05-2010, 09:58 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: 2005 Camry doesn't idle right
Symptoms may be the same, and the also possibly the solution, but the model years are generations different...so I've moved this to it's own thread.
If the IAC valve and ECT sensor aren't the cause, I'd pull the plugs and check for fouling. One fouled with oil (leaking valve seal) or fuel (leaking injector) can cause a rough idle when cold, then smooth out as the contaminant is burned off. Also, check for any trouble codes that have been stored in the ECM.
Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 05-12-2010, 07:46 PM
There isnt any codes stored on the ECM, I recently changed the plugs when this problem first started, the ones i pulled out were fine and didn't have any fouling on them.
