Go Back   Automotive Forums Car Chat > Jeep > General Discussion
Old 05-04-2010, 09:53 PM
johntk johntk is offline
Towing
I have a 1999 Cherokee Sport that I want to tow on a two wheel dolly with my motorhome.
Other than installing a brake controller, strapping the front wheels securely to the dolly, and putting the automatic transmission in neutral, is there anything else I need to do or precautions I should take before towing?
Also, I see Jeep Wranglers flat-towed behind motorhomes more than any other vehicle. Is this my imagination or is there something about those vehicles that make them more conducive to long tow-trips?
Thanks,
John
Old 05-04-2010, 10:53 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Towing
It is VERY important that you put the transfer case in neutral.
Most automatic transmissions react very badly when towed long distances, when the engine is not running. The lack of pressurized lubrication means that the moving parts can be starved of oil and be damaged.
However, the Cherokee, Wrangler and some other SUV's have a neutral position in the transfer case, which allows for long-distance towing without damage.
Old 05-05-2010, 03:26 PM
Re: Towing
Thanks for your reply. I'm not sure what you mean by putting the transfer case in neutral. The front wheels will be off the road, so I assume that takes out any complications with 4WD. Please correct me if this is not the case.
If the gear shift for the rear wheels is in neutral, is that enough to not damage the transmission or differential?
Thanks again for your input,
John
Old 05-09-2010, 01:06 AM
4x4 blazerguy 4x4 blazerguy is offline
Re: Towing
You still need to put the transfer case in NEUTRAL other wise you will burn up the transmission. Check owners manual for towing instructions.
Old 05-09-2010, 09:08 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Towing
+1000; transfer case in neutral, or damage will result!
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 08-11-2010, 03:22 PM
mastertech1964 mastertech1964 is offline
Re: Towing
jeeps should always be towed with the tcase in neutral and the transmission in park or manual trans in low gear
