Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 05-04-2010, 12:47 PM
NOVAZ27 NOVAZ27 is offline
Heat riser gasket???
My 84 Caprice 305 has an exhaust leak around the Heat riser area. After dropping the "Y" pipe down I noticed that there is not a gasket between the top of the heat riser and the exhaust manifold. I could not find a replacemant gasket on any of my local parts houses websites. The top of the heat riser appears to be machined flat while the exhaust manifold outlet has an inner beveled edge that would accept a donut gasket. Has anyone had any experience with the need for a gasket in this part of the exhaust? I could find a gasket, FELPRO #60771, for the 85-90 CAPRICES but not the 84.
The manifold uses the two stud configuration.
THANKS IN ADVANCED FOR ANY SUGGESTIONS.
CURRENT VEHICLES
"84" CAPRICE
"86" SILVERADO
"06" GRANDPRIX GT
VEHICLES IN LIMBO
"69" NOVA SS
"72" CHEYENNE CUSTOM CAMPER
"80" CITATION
"85" SAFARI
Old 05-04-2010, 02:16 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Heat riser gasket???
No gasket needed. Just make sure the nuts on the studs are properly torqued.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 05-04-2010, 08:14 PM
j cAT j cAT is offline
its been a while since I did this but I thought the flat heat riser to manifold surface had a metal gasket...the flare end uses no gaskets as well as the crossover pipes.....
most likely the flare end of the cat conveter pipe is worn/flange rusted badly causing the leak...
the motor mounts if defective will effect this part ...check the motor mounts especially the driver side ....
Old 05-05-2010, 12:08 AM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Wouldn't hurt to use some anti seize on the exhaust bolts upon reassembly just in case you have to take it apart again in the future..
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 05-06-2010, 12:44 PM
Thank you all for the replies. All the information presented was invaluable to solve the problem. My Caprice's 305 "H" exhaust did not require a gasket/s period. I used PAR HIGH TEMP anti seize on the threads. I cleaned the threads with SPRAYON BRAND RUST BUSTER while running the nut up & down a few times.
F.Y. I.
A procedure that I learned when installing the "Y" pipe is to line up the short leg first. Which in my case is the passenger side. Gently snug it up then gently snug up the other long leg side. Check the alignment then torque them down evenly. The leak that was present around the heat riser is now gone. Forget using the air impact wrench. Unless you like replacing studs. Using an air ratchet wrench with low torque is ok for speed work.
THANKS AGAIN FOR THE INFORMATION
CURRENT VEHICLES
"84" CAPRICE
"86" SILVERADO
"06" GRANDPRIX GT
VEHICLES IN LIMBO
"69" NOVA SS
"80" CITATION
"85" SAFARI
Old 05-06-2010, 03:50 PM
F.Y. I.
so the exhaust leaks were the result of y pipe flanges rusted out ?
Old 05-07-2010, 07:03 AM
Rust was not the problem. I had to replace the exhaust manifold a couple of years ago on the passenger side after an encounter with an object that fell off of a trailer I was following. I am figuring the "y" pipe was misaligned & not torqued evenly. When the original repair was made it was winter time and even though I was working in the garage it was cold. The original repair held for about a year then slowly started to leak. Probably from shifting around slightly. This repair seems to be holding. Time will tell. The Caprice has 324k mi. on the od. She is a road car being driven 30-40 mi. daily so the exhaust gets hot enough to burn out the water/acids etc. that cause havoc with the pipes.
THANKS
CURRENT VEHICLES
"84" CAPRICE
"86" SILVERADO
"06" GRANDPRIX GT
VEHICLES IN LIMBO
"69" NOVA SS
"80" CITATION
"85" SAFARI
Old 05-07-2010, 07:36 PM
THANKS
the road salt got to my Y pipe/heat riser flanges/studs..
on replacing with new pipe found pipe not exact like old ...had to retorque a couple of times when pipes hot ..then no more leaks...
the hardest part was the stud replacing...manifold lasted the full 380,ooomi...280,ooo the y pipe failed..
