Old 05-04-2010, 09:36 AM
aliasmax aliasmax is offline
how to remove rear bearing hub 2000 gp gt
I did the search thing and did not come up with the answer so here goes. 2000 Grand Prix GT 3.8. I messed up two of the lug nut studs and need to replace them. I can't get the hub off the car. Took the caliper and rotor off along with the four 10mm bolts for the bearing but the hub won't move. Can someone give me instructions for its removal? Are there any other things i should be concerned about removing the hub, abs, sped sensor? thanks
Old 05-04-2010, 11:05 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: how to remove rear bearing hub 2000 gp gt
Yes there is an ABS plug on the back of the hub in the center. Other than that since you live in wisconsin, use plenty of PB blaster and a big hammer.
Or you could just replace the studs instead of the whole wheel bearing....
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 05-04-2010, 03:42 PM
Thank you for the reply. Thats what i want to do, just replace the studs. So just put some PB blaster in where the four bolts are, unplug the wires and use a big hammer to get it out, correct? thanks
Old 05-05-2010, 10:37 AM
tblake's Avatar
In God We Trust
That or a wheel bearing puller. Leave it soak on panther piss for a while.
When you put the new one on, make sure you sand all the rust off, and before it goes together, it might be a good idea to spead a thin layer of anti-sieze on the mating surfaces so if you ever have to do it again, it will fall off in your hands.
Old 05-05-2010, 11:38 AM
Thank you for the info. greatly appreciated
Old 05-05-2010, 01:08 PM
GPFred GPFred is offline
Don't forget the hub bearing nut. That has to be removed to pull the bearing from the half-shaft.
Old 05-05-2010, 10:49 PM
tblake's Avatar
In God We Trust
Thats just for the front....
Old 05-06-2010, 04:54 PM
Ooops, DOH!! I guess I should read closer. It did say "rear". :0
