Go Back   Automotive Forums Car Chat > Chevrolet > Express | G Van
Old 05-03-2010, 04:16 PM
WayneMann WayneMann is offline
Seperating Plastic Plenum from Intake Manifold
Hi guys,
How do you separate the plastic intake plenum from the manifold? All of the bolts are out, but something is still holding it down. This van has 403,000 miles and I had a water leak and it needs a good cleaning.
Thanks for the help
Wayne Mann
Wayne Mann
Randleman NC
Old 05-04-2010, 07:57 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Seperating Plastic Plenum from Intake Manifold
Originally Posted by WayneMann View Post
Hi guys,
Thanks for the help
Wayne Mann
Wher was water leak and what was done ti fix it?
Double check for any more bolts.
Is there any slack between it and lower plenum?
If so take push down on injector pin plug in housing and rise up on plenum.
MT
Old 06-28-2010, 09:50 PM
Hi MT-2500,
Sorry for the VERY late reply. It had a leaking intake gasket. Replaced the intake gasket and no more coolant leak, at least for now.
Wayne Mann
Wayne Mann
Randleman NC
Old 06-29-2010, 08:21 AM
MT-2500's Avatar
AF - Advisor
Hi MT-2500,
Wayne Mann
Better late than never.
Thanks for posting back how it went.
Did not get a chance to tell you and little late now .
But the intake gasket can be replaced with pulling top plastic cover.
Good luck
MT
Old 06-29-2010, 08:39 AM
Thanks MT-2500,
I had to pull the aluminum intake as well as I had a few sticking lifters to fix, so I pulled every lifter out and cleaned them and now they work perfect.
Wayne Mann
Wayne Mann
Randleman NC
