Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 05-03-2010, 12:12 PM
stb100 stb100 is offline
96 S'brban Ker-thunks Shifting D to R. Plus Rumbles at 50mph +
Hey -- it's an old, K1500 with 180,000. Tires are old 40K, but tons of tread. Two Problems (at least)
1.) When I shift from P to R or D, it makes a nice clank somewhere beneath and back. Runs smooth though except above 50
2.) Make a pretty good rumble at 45, 50 +. Feel it in the seat, etc. Not the steering wheel. My mechanic say tires are cupped and no good. Had free spinbalance put on 'em at TiresPlus, but no better. Tires look good, but are old
THANKS in advance for any help.
Steve
Old 05-03-2010, 05:36 PM
777stickman 777stickman is offline
Re: 96 S'brban Ker-thunks Shifting D to R. Plus Rumbles at 50mph +
U-Joints??
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 05-03-2010, 07:31 PM
j cAT j cAT is offline
Steve
your tires are worn in a condition caused by poor suspension...you need shocks at the least...
clunking and vibs are normally U joints/cv joints or diff bushings etc...could be drive shaft/axle bent or possible wheel bearings..
a person who is skilled can determine these issues fast when inspected on a lift ..
Old 05-06-2010, 09:06 AM
Thanks.
Would like to avoid putting new tires worth 300 to 500 dollars on this old beater. Any other solutions? Could leave as is, but pretty annoying
Can tires be rotated to opposite sides to wear 'em down "evenly" or is that a bad idea.
Can higher air pressure reduce it? Rated at 80psi (like rock). Run at 36 - 40 to smooth out ride a bit.
Old 05-06-2010, 07:22 PM
Thanks.
I rotate tires every 10-13k mi....no tire issues...LT 245-15 R16..load C rated..last set 92,ooomi...1/3 tread left...
rotation and good shocks will keep the tires smooth and evenly worn something important with a 4WD vehicle/ or just a 2wd truck..
Old 05-13-2010, 02:45 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
I'll second the u-joints, plus I'll throw in a worn out driveshaft center support bearing as the source of the rumbling noise. Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
