Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 05-02-2010, 12:48 PM
mxz600 mxz600 is offline
95 ram, headlights just quit working
Everything else works, parking lights, turn signals, brake lights, etc... No warning, just shut it off one day and they next day, no workie. No blown fuses or relays, and one bulb is 4 months old, the other is 2 months old. Is it the switch or is there something else I'm missing?
Thanks,
Jay
Old 05-03-2010, 12:45 AM
bumpyfruck bumpyfruck is offline
Re: 95 ram, headlights just quit working
The headlight switch and the dimmer switch are both common culprits,it was the dimmer switch on my 99 ram 2500.Try pushing forward slightly on the dimmer switch and see if they come on.
Old 05-03-2010, 06:22 PM
indyram indyram is offline
I had the same thing happen to my 1996 one night driving down the road. Just had to replace the switch. It's cheap and took about 10 minutes. If I remember right I just took the dash bezel off and unscrewed the old one.
Old 11-25-2011, 03:46 PM
gsp2112 gsp2112 is offline
i have on 01 sport and the same thing happend come to find out there is a purple/white wire that breaks inside from tilting the steering wheel the outside insulation didnt break just the wire inside (my problem was on the low beam side) and later on the wires pulled loose from the connector inside the wheel also caused by the tilt wheel......this all leads back to the dimmer on the turn signal stem......hope this helps you...i should also mention that mine has the sport package and they have the dual head lamps and the regular one only has single bulbs not sure if it makes a difference in the wiring or not???
The Following User Says Thank You to gsp2112 For This Useful Post:
Chris Stewart (11-25-2011)
Old 11-25-2011, 07:05 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Thanks again gsp2112, this could be useful info for my '01 sport.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 11-25-2011, 07:44 PM
Smile Re: 95 ram, headlights just quit working
you are quite welcome mr. stewart glad i could be of some help to you
