Go Back   Automotive Forums Car Chat > Dodge > Ram Van
Old 05-02-2010, 09:16 AM
urbankmd urbankmd is offline
1979 Ram Van ignition issues...
Completely lost at this one. I have a 79 ram van that I did an engine swap on. For some reason it destroys distributors, the pickup coil on the inside. I am on my 5th one. I have replaced the ballast resistor, ignition switch, voltage regulator, starter relay, and many other parts but still have the same problem. I can put a new distributor and the van will start right up...
Open to any and all suggestions
Dallas
Old 05-02-2010, 04:58 PM
alloro alloro is offline
Re: 1979 Ram Van ignition issues...
The cam bearings could be worn. The result is a lot of side pressure on the distributor shaft, which in turn throws the pick-up coil out of whack.
