Old 05-02-2010, 01:49 AM
dizzle1's Avatar
dizzle1 dizzle1 is offline
AC blowing Hot/Cold air through vents, car has Manual climate control
System had good pressure last time I checked.
Blend door actuator could be bad, I do get Drivers HOT/COLD Passengers air in every setting its most noticeable with the AC on, except when using heat.
AC Compressor could be leaking through seals I think “krivasauto” has a write up on it with a rebuild.
These are the only known culprits I can think of. Can anyone with manual climate controls relate to this issue or some serious answers to this issue which has plagued many W-body owners?
Check the heater blend door actuator through Heat & Air Conditioning, I read that it can be accessed by removing the drivers side kick panel.
http://www.rockauto.com/catalog/raframecatalog.php
2000 Intrigue GX 3.5 110k
Mods: Cold Air Intake, Polished Intake Ports, 12inch front Brakes, Dorman front Swaybar
Old 05-02-2010, 02:30 AM
rhaigh08's Avatar
rhaigh08 rhaigh08 is offline
Send a message via AIM to rhaigh08
Re: AC blowing Hot/Cold air through vents, car has Manual climate control
My 2002 blows air hot/cold still when its off. Not much but its there. My 99 did that and when we replaced the blower motor/resistor it stopped. I have a blower motor resistor job in my future only 2 settings work for the blower high and highest 3 if you count the very low setting when its off.
Old 06-19-2010, 02:55 AM
dizzle1's Avatar
All my buttons are working properly for the climate control unit, would it still be the blower motor resistor. I have to check the pressure didn’t check it since late fall and if its low ill do a AC Freon Refrigerant dye test.
Old 09-08-2010, 10:43 PM
RCC RCC is offline
yes check your pressure om ac there low i bet had 99 do the same way
