Old 05-01-2010, 10:46 PM
TEANER TEANER is offline
Question No CAT, service engine light help???
I have a 2002 Chevy Silverado Z-71....took off converter and put Flowmaster pipes on my truck....the check engine light came on and I took it to Autozone and they told me it was the codes for the converter...I was told that I could fix it with installing a cheater/stimulator...I installed the cheater/stimulator and the light went off and then it came back on again. Can anyone tell me how I can fix the check engine light from coming on without having to replace my converters?
Old 05-02-2010, 08:15 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: No CAT, service engine light help???
It is illegal to remove cats if you operate it on a federal funded highway.
Also.
Engine will not run right without them
Put them back on and your problem will be fixed.
MT
Old 05-02-2010, 12:08 PM
mcmalloy mcmalloy is offline
you can buy hi performance cats that dont restrict air flow
Old 05-02-2010, 02:00 PM
maxwedge maxwedge is offline
A990 racer
It is not a matter of air flow, the sensor cannot mask nox for one. put tape over the lite, obd11 enhanced is very sensitive as designed.
Old 05-02-2010, 07:47 PM
j cAT j cAT is offline
too bad you did this to your vehicle with out first checking these forums...this post is one of many , that have learned the expensive way ....these vehicles pcm/computer controlled engines will run worse not better with your ideas ...
return the engine controls/componets to original....if not poor performance ...will result.
Old 05-03-2010, 12:45 PM
Mango™'s Avatar
Mango™ Mango™ is offline
lol MAX. tape the lite!
