Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 05-02-2003, 11:59 AM
03RedMatrix 03RedMatrix is offline
Keyless entry
I would like to know if anyone could help me with information on programming a keyless entry fob (FCC ID: GQ43VT14T) for a 2003 Toyota Matrix?
Thanks,
Jeff
Old 10-22-2003, 02:36 PM
amtbikedude amtbikedude is offline
Thumbs up Keyless Entry Programming Instructions
Here, I've posted this site on another thread but it's a great site for information on programming you're Keyless Entry or your VIP RS3200 Security systems. They have instructions for both.
Toyota Keyless Entry Programming Instructions.
Good luck!
Old 02-10-2004, 07:20 AM
RobertTank RobertTank is offline
Re: Keyless Entry Programming Instructions
Good luck!
I have tried this site. The instructions do not work for either my 04 highlander or my 04 matrix. Surely there must be instructions out there somewhere.
Old 09-01-2004, 01:12 AM
spotco2 spotco2 is offline
Banned
Re: Keyless entry
Here is the procedure for the Matrix
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=7916694912
Old 09-15-2004, 09:20 PM
jhamm15 jhamm15 is offline
Where can I buy the factory/oem security system for a 2004 Corolla, I think I've seen one on ebay in the past but didnt know if it came with installation instructions.
Old 01-15-2005, 05:07 PM
25259250 25259250 is offline
Toyota Corolla keyless programing 1998 - 2001 remote
check this procedure, it works for me on a 1998 1999 2000 2001 toyota corolla keyless remote programing , is easy and fast. If you have a second remote just push the same button until light and horn chirps again.
FCC ID: BAB237131-022 CANADA: 2024 101 526
http://www.4runners.org/articles/rs3000/
RS3000 programing is not the same as RS3200
Old 02-14-2005, 12:03 AM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Re: Keyless entry
This is the correct procedure for the Matrix/Vibe:
1. Driver door open and unlocked. Key out of the ignition
2. Insert the key and remove 2 times in 5 sec.
3. Close and open driver door 2 times in 40 sec.
4. Insert the key and remove it again from ignition.
5. Close and open driver door 2 times in 40 sec.
6. Insert the key in ignition,
7. Close the door,
8. Turn to on and back to lock in 1 second intervals. 1 time for add, 2 times for rewrite, 3 for confirmation 5 for prohibition. (yes, there is no “4”)
9. Remove the key
10. Power lock will cycle to confirm
11. For add or rewrite mode within 40 sec of the confirmation,
A. press “lock” and “unlock” buttons of the FOB at the same time between 1 and 1.5 seconds.
B. within 3 sec press “Lock” button for more than 1 sec and release.
C. If it’s correct, the power door lock will cycle once. If it’s wrong the door lock will cycle twice.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Programming Keyless Entry for MAZDA 6 Mazda6ownr 6 7 09-26-2013 04:46 AM
1998 Toyota Avalon XLS Keyless Entry Programming Instructions kattate09 Avalon/Pronard 1 02-04-2010 04:58 AM
94 s10 remote keyless entry programing instructions needed stillblazin Problem Diagnosis 0 07-01-2009 09:39 PM
remote keyless entry problem smity9089 Intrigue 0 04-13-2009 11:45 PM
06 Camry LE - How to program keyless entry pshrivas Camry/Camry Hybrid/Vista 0 03-20-2009 02:54 PM
