Old 05-01-2010, 01:10 PM
wormjerky wormjerky is offline
1989 F150 Starter Relay???
1989 f150 302 5.0........ does this truck have a starter relay and if so where is it located?? Thanks for any help!!!!
Old 05-01-2010, 06:20 PM
mcmalloy mcmalloy is offline
Re: 1989 F150 Starter Relay???
dont think so . it just has the sloniode buy the battery
Old 05-01-2010, 06:40 PM
old_master's Avatar
Advisor/Moderator
The starter relay, (sometimes incorrectly referred to as a solenoid) is located near the battery. The positive battery cable goes directly to one terminal, the cable on the other terminal goes down to the starter. The smaller terminal on the relay is what energizes the relay. Vintage Ford starters do not use a solenoid on the starter.
You have to know how it works,
to figure out why it doesn't.
Old 05-02-2010, 04:26 PM
jyount jyount is offline
He's right, the one on the fender is what you are looking for. My 90 302 did have a solenoid on the starter, are you sure? when was the break point?
Solenoid - not only does it switch power too in the case of a starter solenoid, but the main function of it is mechanical power source, ie it moves the bendix of the starter into the flywheel in that application.
Relay - basically, a means of using small low amperage wires to electrically switch big large amperage wires, so you run the big current through the relay, not the switch and burn out the contacts...
all it is there fore is to "relay" power.
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
