Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 04-29-2010, 06:15 AM
shawnro30 shawnro30 is offline
Angry 2007 chev tahoo engine noise through speakers
My 07 tahoo ltz I can hear a whining sound in the speakers of the radio. Sometime It wont do it but it has gotten worse and now it does it all the time. It will stop for a little bit if you turn the radio off but like it you hit a bump in the road or turn the passenger side blinker on it would start back. I think its coming from the little speaker up by the windshield but not 100% sure. I am sure its comeing from my radio though anyone have any suggestions or help would be greatly appriciated this thing is starting to drive me crazy.
Old 04-29-2010, 11:53 AM
Re: 2007 chev tahoo engine noise through speakers
Its comeing out of the passenger side speaker in the door does anyone know how to take the door panel off ??
Old 04-29-2010, 08:26 PM
roadrunner2 roadrunner2 is offline
You may have a bad ground connection.
Remove two screws by door handle.
Use a thin flat forked tool to loosen the panel from the plastic 'Christmas trees'. They are spaced about six inches apart.
Once loose, lift up to remove, (it comes out easily) so be careful you don't break the speaker connection.
The problem with doing nothing is not knowing when you're finished.
Old 04-30-2010, 12:15 PM
j cAT j cAT is offline
if this whine noise is only from this speaker try another speaker just in case it is because the speaker is defective ...
these speakers do not go to ground ...ground return on speakers is a no no ....
I suspect that the radio /amplifier is in need of repair...
if this is an aftermarket radio then anything is possible as most are not installed properly
