Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-28-2010, 11:34 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Valve replacement - head
Anyone have a link on what to check for to see if valves need to be replaced. None are bent, but a couple are blackish. Ill post pics up tomorrow, just seeing if I should rebuild the head or not.
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 04-30-2010, 03:56 PM
Re: Valve replacement - head
They all look like they seat properly...for one cylinder it looks like the intake/exhaust valves are slightly open but I think thats just the position of the cam. I need to adjust everything before I get a timing belt.
95 Eclipse GS-T
Currently:
Soon lol
Old 05-01-2010, 05:02 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
How many miles are on the head. If it has never had a valve job I would go ahead and get one done. You dont have to put new valves in just have a shop regrind the seats.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 05-02-2010, 02:20 AM
RSLaser RSLaser is offline
If you have the patience, and some elbow grease, get some valve grinding compound and turn them by hand. Saves some money, and in most cases, time. Ive yet to find a drill that I can attach to spin them, but turning them with a rag for grip works fine for me.
1991 Plymouth Laser RS
Only sat for a few years....
Old 05-02-2010, 08:16 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
if the head is off, you can pour some oil into the intake/exhaust port and see if it leaks around the valve. This is assuming that the valve is still being held in place by the spring.
I would get new valves if you are going to get the seats redone. Then you don't have to worry about that carbon build up and such. I like new stuff.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 05-02-2010, 10:20 AM
This is what they look like, once I turned the exhaust cam a 1/4 turn the exhaust valves in cylinder 3 seated correctly.
95 Eclipse GS-T
Currently:
Soon lol
