Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-28-2010, 07:42 PM
mad419iou1 mad419iou1 is offline
2007 GT died out of nowhere....won't stay running now
Think it's a pretty sweet ride home today, dude with a BRIGHT orange Challenger revs at me at the light. Light turns green, drop the clutch, starting to pull away a bit, hit 2nd, go to hit 3rd......BLEH car dies. I coast my way into the DD parking lot, try to start the car, runs for about 3 seconds and dies. No throttle response, nothing at all. Turn the key off, try to start again....same deal, car starts, revs to about 1500 before slowly falling to 500 and stalls in about 5 seconds. Had her towed to the shop. Anyone have any ideas?? TPS.....cam sensor....throttle body....fuel filter maybe???
Old 04-29-2010, 11:20 AM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: 2007 GT died out of nowhere....won't stay running now
Check fuel pressure at the rail with engine off and idling (as best you can before it quits). If the pressure drops off significantly when engine is running that is the cause of it dying and is either a very clogged fuel filter or a dying fuel pump.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 04-29-2010, 12:00 PM
Looks like it turned out to be a bad MAF sensor.
Old 04-29-2010, 12:38 PM
Ouch, that costs quite a bit for a little thing. Make sure you clean the MAF sensor periodically using CRC MAF Cleaner. You just spray the sensor with it and that's it. It will keep it reading accurate and from overheating and snapping from buildup on it.
