Old 04-28-2010, 06:53 PM
caffeineaholic's Avatar
caffeineaholic caffeineaholic is offline
'97 LeSabre will not start; belt just twitches
Hi all,
My friend has a 1997 Buick LeSabre (fuel injected V6) (about 140,000 miles) and for some reason the car try's to start but it will only "twitch" the belt. In other words it tries very hard to start but it seems like something is keeping it from going.
The battery voltage is good (and it hasn't been drained to much we only tried starting it sparingly). The starter is good I believe.
It sounds like it has a lot of torque when trying to start it and the starter tries very hard to make the belt just move about 1/2 an inch. It almost seems like the belt is too tight or something but it seems to have normal tension. When it quickly gets to that 1/2 inch or turning it makes sort-of a metal sound like metal hitting metal but not like a "ping" its a little more of a deeper sound than that.
I have also checked all fuses both under the instrument panel and also under the hood.
I don't know what to check next. The starter solenoid? Something else? I have little experience in front wheel drive cars.
Thanks.
1985 Chevy Caprice small-block V8 305ci (5.0L) - 4-Barrel Q-Jet (E4ME) - 700R4 - 115k+ mi. - resonator and A/C components deleted.
Driven in severe weather most of the year (Arizona 100+ degrees during summer heat or in wet weather especially in harsh monsoons). About 30/70 highway/city driving.
Old 04-28-2010, 07:34 PM
Mickey#1 Mickey#1 is offline
Re: '97 LeSabre will not start; belt just twitches
The upper intake manifold can fail & fill the cylinders with coolant. We refer to this as hydrolocking. You can pull the plugs & see if it turns over. Has he been losing coolant or is it low now?
Old 04-28-2010, 07:37 PM
I did notice that his coolant level was a little bit low and that the reservoir was completely empty. I will ask him (but he won't be available until after 10pm MST).
I forgot to mention that the car has about 140,000 miles on it.
Old 04-28-2010, 07:44 PM
Tell him not to keep trying to start it. I've seen broken starters & bent rods.
If it is hydrolocked then he'll need a new upper intake & should also change the lower intake manifold gaskets.
Old 04-28-2010, 07:46 PM
Okay, I'll let him know. Are you pretty sure that this is a likely reason or do you think that it could be other things?
If you're pretty sure, should I just dive in and take the intake manifold off and I guess look for coolant?
Old 04-28-2010, 08:05 PM
I'd confirm it's the intake before diving in. You can put a socket on either the crank bolt or alternator bolt & see if the engine rotates counterclockwise but not clockwise, that'll confirm its hydrolocked. You might also find coolant in the hose that connects the throttle body to the air cleaner housing. You should still pull the plugs & get the coolant out of the cylinders as soon as possible. I'll send you a private message with a link to an article on the upper intake failure.
Old 04-29-2010, 10:04 AM
I pulled each spark plug out last night and 1,3,5 in the front area of the car all poured out a ton of coolant while the rear ones 2,4,6 didn't seem to pour much if any.
It was dark out so it was very hard to tell...
Thanks for your help; is there anything else I should worry about or should I just get started on getting a new intake and gasket? (and I still need to finish reading the 1st link and start reading the 2nd link which I will do).
Old 04-29-2010, 06:11 PM
imidazol97 imidazol97 is offline
AF -Advisor
I would drain out the oil in it now before you run it after you finish replacing the upper and the gaskets including the gasket under the metal lower intake.
I would put in 4 quarts of cheap oil before you start it, Walmart's brand would be economical. Then after the car has run for many minutes when repaired, drain and refill with clean oil again. Don't forget to change the filter that time.
You might also want a set of fresh spark plugs.
Good luck to you.
Old 05-01-2010, 01:23 PM
Will do.
Thanks.
Old 05-31-2010, 06:38 PM
Sorry it's been about a month (been busy). I have finally pulled the UIM off and found the pool of coolant.
I was surprised that all of the ten UIM bolts were either just barely finger tight or just a big snug. It took no effort to take any of them off and a couple could be taken off just with my fingers.
Does anybody think it is possible that this could simply be the issue? I cannot see any damage to the UIM but it is difficult to tell...
As always I appreciate your input. Thanks!
Old 05-31-2010, 06:55 PM
maxwedge maxwedge is offline
A990 racer
I would do the upper intake and lower gaskets while apart.
Old 05-31-2010, 07:14 PM
Do you think it is possible that the coolant simply got in because the upper intake manifold was not tight enough? All ten bolts that secure it were barely finger tight or just barely snug.
Also, does anyone know where this short metal tube goes? (see attachment). I noticed it was in the fluid once I cleaned the fluid out. Perhaps it goes in where it is laying? At the EGR port? Does it just fit snug in there?
The camera was facing where the throttle body would be; the EGR metal hose is right below it.
Last edited by caffeineaholic; 05-31-2010 at 08:06 PM. Reason: Added an attachment and add'l question.
Old 06-02-2010, 01:10 PM
Yesterday I also took the LIM off and found that the gasket was very old and torn up. I will replace the LIM, retorque everything proper and do the same for the UIM.
Can a loose LIM and/or UIM and bad gaskets account for an oil leak? The motor leaked a lot of oil but it seems to be from near the top of the engine...
Thanks for your input.
Old 06-19-2010, 05:54 PM
The problem was solved:
I replaced all gaskets after the coolant was removed and tried to start the engine (thinking the LIM gaskets were the cause). The engine still would not start but tried very hard and almost did.
Upon later more closer inspection of the UIM the hole for the EGR pipe was indeed breached and i could even see through the hole in it.
I replaced the UIM with a better one that solved the issue (on this link: http://www.ineedparts.com/auto-parts...kit-17806.html) It's $106 USD after shipping.
After reassembly the car started just fine and runs like normal.
Just thought I'd share.
Old 06-21-2010, 09:57 AM
AF -Advisor
Did you change the oil after rebuilding it to get the last coolant out of the oil.
Tags
belt , intake , start , starter , uim
