Old 04-28-2010, 05:55 AM
deansplit deansplit is offline
What size cable/wire for indicators
Hi
I'm adding B-post indicators to a campervan - what gauge/amp load wire/cable do I use?
Thx
Old 04-28-2010, 06:43 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: What size cable/wire for indicators
Are you adding LED indicators or incandescent bulb indicators? What wattage are the bulbs? LED indicators draw very little current so you could get away with some pretty small wire for them. If you are using standard incandescent bulbs and don't know the wattage, they may have pigtails already installed and you could go with the same gauge as the pigtails, likely around 16 or 18 gauge. Also, make sure you either tap in to a circuit that is already fused or install a fuse.
-Rod
Old 04-28-2010, 06:47 AM
Hi - They're 5w bulbs. I was just going run a wire from the current front indicators. Will that be OK?
Old 04-28-2010, 09:26 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
As long as the total load doesn't exceed the fuse's amp rating for that circuit, usually labeled "TURN" in the fuse block diagram. More than likely you should be fine adding the two small lights...each one adds ~420mA to the circuit load (5W / 12V = 0.42 A)...though as mentioned before, LED versions draw alot less so adding those puts less added load onto existing fuses.
18 AWG should be fine for a small, intermittent load such as turn signal lights and even if they serve double duty as side markers. You could go smaller, to 20 AWG, but no need to run to the store for it for this small a job. Just use what's on hand.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
