Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 04-27-2010, 10:03 PM
JESSICAR JESSICAR is offline
Send a message via AIM to JESSICAR Send a message via Yahoo to JESSICAR
How to remove a clutch fan?
1999 Ford Ranger 3.0
Anyone know a way around having to purchase the specialty tools (wrench set) to remove the clutch fan???
Any help appreciated!
Old 05-11-2010, 09:24 AM
86bronco2 86bronco2 is offline
Re: How to remove a clutch fan?
ford fan clutch removal wrenches @ your local parts shop.There is two wrenches one to hold the pulley and one to remove the fan. Remember they have left hand threads.
Old 05-12-2010, 12:02 AM
diezelman's Avatar
diezelman diezelman is offline
Send a message via Yahoo to diezelman
As stated you can borrow one from the parts store. Your manual wont describe to well how to get it off. Once you have the belt off, you will need to remove the pully on the clutch. 4 bolts. Then slide that puly back towards you and put the bolts back in. You will use the tool on these bolts to keep the shaft in place. In my experiance the other wrench dosnt fit over the large nut on the shaft. I just use a large cresent wrench on it. It's a tight squeeze but it works. Remember your going to go counter-clockwise on this clutch fan. Once you get it broke free its easy street from there. Just re-assemble in reverse. Dont lose the 4 bolts for the puly!!!
JP
Old 05-12-2010, 12:17 AM
Scrapper Scrapper is offline
AF Premium User
i would remove shrowed and radiator also if you wasn't going to try it a quick way because you can end up paying allot more than just a fan. just a thot you should know if you wasn't going to remove these?
