Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 04-27-2010, 09:40 AM
jpawl jpawl is offline
Smile Bleeding procedure
99' tahoe
changed master due to sinking pedal but can't seem to bleed this front ABS system down properly.
yes,i bled it correctly procedure wise(master and whole sytem) but i think with this system i might need to bring it to the dealer as to actuate the ABS manually with their scan tool.
is this right or am i missing something?
thank, jpawl
Old 04-27-2010, 11:37 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Bleeding procedure
Originally Posted by jpawl View Post
99' tahoe
thank, jpawl
May be.
You might try bleeding with key on.
MT
Old 04-27-2010, 01:28 PM
Originally Posted by MT-2500 View Post
May be.
That I didn't do. I did it with key off and engine running but not KOEO.
Once I find the prob I will let you know.
Old 04-27-2010, 03:38 PM
777stickman 777stickman is offline
I looked in my '98 C/K factory manual and it did make reference to using the scan tool for ABS bleeding. If that's the case in the real world, I can't say.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 04-27-2010, 06:04 PM
j cAT j cAT is offline
99' tahoe
thank, jpawl
recently some have had with the old body style The ABS module causing your issue of the sinking pedal ..they went to the scrap yard and they picked up one this solved their problem...
they had no leaks ....
Old 04-28-2010, 08:59 AM
Thanks for looking it up.The fix had to go through the dealer.Cost me $91.95 to do a automated bleed with their GM scan tool.
Thanks to all involved for the help.
