Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-26-2010, 11:36 PM
chevyboy_21 chevyboy_21 is offline
Exclamation 96 eclipse rs smokes at idle and engine light
2.0 dohc non turbo auto tranny mainly smokes blue when idle and keeps popping engine light on p0300 multiple cylinder miss fire replace wires plugs and coil cam and crank sensors still getting the light
Old 04-27-2010, 09:54 AM
jpawl jpawl is offline
Re: 96 eclipse rs smokes at idle and engine light
check your plugs again and see if they are oil soaked.valve seals could be bad and causing both problems.
