Old 04-26-2010, 09:22 PM
icekreamkilla icekreamkilla is offline
my tire is stuck
my tire is stuck on the studs....i kicked it and all that mess.....yes it is clear of the ground....i dont know what else to do....ne help would be great
Old 04-26-2010, 09:32 PM
jrecken jrecken is offline
Re: my tire is stuck
I know one way that works. Not sure if it is recommended.
Back off the lug nuts a little and drive the truck until it breaks free. It should not take very far.
Old 04-27-2010, 08:10 AM
j cAT j cAT is offline
loosen the lug nuts two turns,,,,, then driving a few feet and turning the steering wheel left /right will loosen the rim from the hubs...when ever you have alloy wheels you need a small amount of antiseize compound on the hub area ...
do not get any lube/antiseize on the lug studs...
you can get injured or damage the vehicle if you try to hammer/sludge off the wheel ...especially when on a jack ...
Old 04-27-2010, 10:46 AM
Kevcules Kevcules is offline
This happens to mechanics all the time,we just don't see how they remove the tire. I tend to watch every time my vehicle is in there. It doesn't happen to me as I lube the mating surfaces of the rim to rotor, drum etc. They take a large hammer and tap firmly on the rim,just outside of where the lug nuts are.As they tap they are moving around the rim.If you have alloy rims,you can only soak the area with penetrating lube and hope it frees up.
If your stuck,bring it to your shop and watch them...
Kevin
Old 04-27-2010, 04:39 PM
so here is my solution. i jacked her up. took lug nuts loose. sprayed with pb breaker. then took a short 2x4 and put it against the lip of rim and tapped with a 2lb hammer. then switched to opposite side. came right off. thanks to everyone for their tips.
Old 04-27-2010, 05:09 PM
kahjdh's Avatar
kahjdh kahjdh is offline
We have a 10lb plastic sledge at the shop that does the trick.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 04-28-2010, 10:02 PM
cramer_77 cramer_77 is offline
happens to me all the time(only mechanic in a 3 bay shop) sometimes you can kick it, theres been a few steel wheels that we had to heat up. But as far as alloy, we've gone as far as getting a small piece of 2x4 setting it on the rim and hitting it with about a 10lbs sledge. I've heard of just barely loosening your lugs and lowering it to the ground and shaking the vehicle back and forth to break them loose but never tried it.
01 Silverado 2500HD, HID lows and highs, cold air kit, leveling kit, brush guard, dual flowmaster outlaw mufflers, 5% windows.
Old 05-09-2010, 10:23 PM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
ive seen a few cars with stuck wheels. normally a dead blow hammer works or a rubber mallet smack to back of wheel or tire a few times always worked for me
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
