Old 04-26-2010, 05:39 PM
thisisdrivingmenut thisisdrivingmenut is offline
ABS light 02 Sonoma
ABS light came on the other day; I can’t get the truck to my mechanic until next week. Brakes seem to be fine. Are there any quick physical checks I can do to see what the problem may be?
Old 04-26-2010, 07:24 PM
old_master's Avatar
Advisor/Moderator
Re: ABS light 02 Sonoma
An ABS capable scan tool is necessary to retrieve the DTC's and diagnose the problem.
You have to know how it works,
to figure out why it doesn't.
Old 04-26-2010, 07:46 PM
mechanic1980 mechanic1980 is offline
you can look at the back side of the wheels and see if you can see the tone ring for abs they split and can throw a light
Old 04-26-2010, 10:58 PM
FishFind FishFind is offline
One Hot Shot
Check the ABS wires and make sure they are not cut. mine did that. It is on the front side of the control arm and is connected inside the control arm with a small bolt. It is only about a foot long until the plug so you can check it easy. Next make sure you dont have any garbage that is up by the sensor its self. I also had a nice ball of string that got stuck infront of my sensor. You can also shoot some brake cleaner on the abs sensor to clean any dirt off. The abs lite will come on when it does not detect a signal from the rotor, so it thinks that the brakes are locked up. Most of the time it is a cut/bad wire or sensor or just a dirty sensor that cant read the rotor.
Old 04-27-2010, 08:32 AM
Hey thanks guys. Gonna check behind the wheels later today will report back. I was thinking a broken wire to a sensor as well. Tell ya what I find or what I don't
thanks again
