Go Back   Automotive Forums Car Chat > Pontiac > Sunbird/J2000/2000 Sunbird
Old 04-26-2010, 04:36 PM
fonnzy8's Avatar
fonnzy8 fonnzy8 is offline
90' Sunbird NO SPARK
A buddy of mine has a 90 sunbird le 2.0 ltr. and it just died on him on the way home. I came over to take a look at it and we aren't getting any spark at the coil. I have checked the relay's and fuse but am now stumped as to why we aren't getting any spark... Anyone have this problem before.
Old 04-26-2010, 08:04 PM
mechanic1980 mechanic1980 is offline
Re: 90' Sunbird NO SPARK
sounds like a crank sensor to me hook a scan tool up and read the rpm signal if it reads zero when you crank the sensor isnt working
if it starts in the morning without doing anything then suspect the ignition module
Old 04-27-2010, 12:14 PM
fonnzy8's Avatar
It won't start at all. No spark at all but have no idea how to check the crank sensor. Are they expensive, and are they easy enough to change?
Old 07-15-2010, 05:41 PM
andretti andretti is offline
This engine doesn't use a crank sensor to signal spark timing. Inside the distributor cap is the ignition module and pick-up coil. The pick-up magnetically senses the position of the "rotating" camshaft and sends its reading directly to the module. It's the ignition module that controls the firing of the ignition coil and also sends its timing signal from the pick-up to the ECM (electronic control module inside the car) which then fires the fuel injectors.
First things first. All the fuses are good so next check to make sure the camshaft is rotating. Post back what you find and I'm sure others here will also chime in to help.
OOPS!!! I never looked at the POST DATE! lol
