Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 04-26-2010, 12:30 AM
pint4 pint4 is offline
2000 SSEi Brake Problems
I have 3 dash lights that came on at the same time-"Brakes", "Trac Off", and "Anti-Lock". I replaced my rear brakes as they were bad. I thought this might fix the problem but it didn't. The lights are still on. Any suggestions as to what I need to look at next. My scanner didn't clear them so that wasn't the answer. I am trying to get 1 to 2 more years out of this car which has 147,000 miles on it, and then I can buy something better when my two children are out of college. Any help would be appreciated. I am hoping it is something not too complicated or expensive to fix. This car has been the ultimate money pit.
Thanks
Old 04-26-2010, 08:25 AM
tempfixit tempfixit is offline
Re: 2000 SSEi Brake Problems
Check the abs wires on the front wheels by the basll joint area for broken wire. or bad wheel beariong. In order to scan it you need a abs capable scanner. Usually for about $35 someone wwill scan it and tell you were to start looking.
Old 04-26-2010, 10:46 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
I agree. The ABS scan will help you narrow down the possibilities.
