Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-25-2010, 01:52 PM
DaChevyClassic DaChevyClassic is offline
HID Problem...
I got 10k H.I.D. in a 94 caprice. I have 2 keep turnin' the headlight switch on and off for both of them 2 come on. Do I need 2 change my fuse or what???
Old 04-25-2010, 08:42 PM
j cAT j cAT is offline
Re: HID Problem...
10k lamps could get the cops on ya...if your watts are too high above 55watts you will need to reduce to a lower wattage....or the ballast is bad drawing too much current ....can you measure the current flow amount ?
Old 04-25-2010, 09:43 PM
Re: HID Problem...
On the ballast. It say each bulb is 35W.
Old 04-26-2010, 09:22 AM
Re: HID Problem...
somehow you have a overcurrent ....too many amps will cause your problem ...35watts is good ...you must measure the current to see if the ballasts are defective..also you must check your wiring as if it is shorting out this will occur as well...............
the wires need to be covered with loom and secured ...
connections secure with the use of the proper lug fasteners and even solding and heat shirk to protect the connections from corrosion / shorting out ...
