98 silverado wont start help needed.
I just finished replacing the intake gasket that was leaking and got it all back together and now it wont start. Tried a bit of starting fluid and it fired right up then stopped when it ran out. Im thinking maybe check the fuel pressure once I get a gauge. I had the fpr off and the fuel lines were off when cleaning inside the upper intake you think maybe the 0-rings are not sealing now? I did not remove the injectors or anything from the cluster.
Re: 98 silverado wont start help needed.
Check for fuel pressure first make sure everything is properly reconnected.
Thanks ill get the pressure checked and report back.
Its fixed! I checked the fuel pressure and that was fine. Decided to go ahead and order the new mfi unit from O'Rileys put that in and its allll smooth now.
