Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 04-23-2010, 01:30 PM
JMiller1991 JMiller1991 is offline
@@@ 91 Camaro RS v6 not getting anypower @@@
Replaced the starter, but put hooked the wires on backwards, and so when I went to go hook the battery back up the starter would engage as soon as i put the ground back on and would spark, (keys are not anywhere near the ignition). So I took the ground off the battery and went back under the car to xwitch the wires back the way there suppose to be. Came back up and hooked the battery up and now not getting any power at all.
I checked the battery still got full juice, so took the starter back out had it checked at local Auto store, works. So i checked the fusible links and there all good, still getting full power to the starter. So next i checked the ignotion coil also getting power. Dont know where to go from here!?
Any suggestion?
PS also checked fuses under dash on driver side all working
Old 08-14-2010, 03:38 PM
Kasadya Kasadya is offline
Re: @@@ 91 Camaro RS v6 not getting anypower @@@
Did you ever figure out whats wrong, cause im having the same problem just about. except i still get my lights inside my car.
