Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 04-23-2010, 11:36 AM
rubs rubs is offline
Stiff steering wheel and lot of noise
Hi,
We have a 98 camry with 216k miles. Recently we notice that when we move the car from parking and turn steering wheel it appears very stiff like someone on other side is trying to resist it to move and also a squealing noise coming. When car is driving there is no issue or steering wheel issue so we only feel it while moving the steering wheel when moving the car from parking.
What can be the possible issue?
Thanks
--rubs
Old 04-23-2010, 04:48 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
Re: Stiff steering wheel and lot of noise
Start by checking/tightening the tension on the power steering belt.
Mike
Old 04-23-2010, 05:45 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
Maybe the ball joint or tie-rod are out of alignment. The stiffing is constant all along the wheel rotation or only after half of turns? If it's not constant, the car is dangerous to drive and need to be inspected underneath ASAP.
But if the seering wheel is hard to move at stop/low speed whenever the wheel angle, it can be a power steering issue, like Mike suggest. Check PS fluid level. Let it idle and turns wheel with cap removed to remove air. And check the belt and tensionner.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 04-24-2010, 09:42 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
You may need to flush the PS system and replace all the PS fluid.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 05-10-2010, 04:17 PM
I replaced both the drive belts and looks like resistance is gone and no noise while doing turn but there is still lot of noise coming and I drop by at mechanic and he indicated that problem is due to exhaust flex pipe and it is very expensive to replace but he can fix it by just replacing the bad piece and weld it. Does it makes sense or anyone else had same issue?
Thanks
--rubs
Old 05-10-2010, 04:30 PM
Yes, weld it is a good idea. I already do that and it repaired the problem. It cost only 80$ instead of 550$ (in my case).
Old 05-10-2010, 11:23 PM
AF -Advisor
Yes, cutting out the broken flex pipe and welding in a new aftermarket one is a viable alternative to replacing the entire pipe. Had it done about 2 years ago on my 94 Camry. Cost here in my area (Chicago area) was around $150.
Mike
