Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '01-'05 Civic
Old 04-22-2010, 03:56 PM
Ninety7PrixGT Ninety7PrixGT is offline
I Ain't No Newbie
Angry Beyond frustration with sensor codes
Ok right to it. 02 hx coupe 2.0. Car was just fine. Got in a bang up a yr ago. Front end damaged quite a bit but not engine wise. Sat for about 45days before the garage got to fixing it. 5500 later, the thing runs like a pos. Evn aftr th accident, it was mostly drivable, and certainly ran fine. It sat during winter months, in vermont, so it was cold. Get it back last April and it is craziness. I was getting a code saying that the fuel/air ratio system had a prob. And everywhere says that that is the o2 sensor. Ok so it went back to the same garage, not my decision, and they supposidly replaced it with another one, and then another one when that didn't work, then said they had no clue. It constantly surges while driving. Worse up hill, morning, and cold. But it's as consistent as a clocks second hand. Just skip and sputtering everywhere. So now it's April of next yr and the inspection is due and I, this time, am trying to figure the stupid thing out still. Got codes last night. P1167, p0171, p1164. Ok, certainly don't tell me much. Is it the o2 sensor? Coils? Plugs? Tps sensor? I'm getting plugs now but nothing is ever that simple with me and cars. Anything to help would be much appreciated. Thanks
97 Tour GL
Cold Air Intake
2 1500w 12" Alpine Type-R's
1000w Alpine Mono
250w Rockford
5 Farad Planet Audio Capacitor
Infinity 200w 5x7's, 250w 6x9's, 100w Dome Tweeters
Kenwood KDJ Deck
Old 04-22-2010, 07:26 PM
a1txtech a1txtech is offline
Re: Beyond frustration with sensor codes
you may have already had this suggestion, but see if you can find someone to perform a smoke test on the emission system..sound more like a vacuum leak ..you might even have a loose ground along the core support..
i hope this helps
Old 04-23-2010, 04:10 PM
I Ain't No Newbie
No. Hasn't been mentioned. I looking for as many suggestions as possible. Need every one until it's fixed. Thank you though. I will see if I get any where with. Thanks
97 Tour GL
Cold Air Intake
1000w Alpine Mono
250w Rockford
Kenwood KDJ Deck
Old 06-01-2010, 12:33 PM
andretti andretti is offline
I don't think a vacuumm leak would generate your 3 codes.
You should verify the upstream (#1) sensor WAS replaced. If it visually looks new then carefully inspect the harness from the connector to the firewall. If the sensor is new then I would guess one of the four wires to the ECM are open or shorted.
