2002 grand prix gtp fuel pressure
where should the prssure be at. i tested iut the first time and it said 46. then i tested it again and it kept bouncing back and forth from 44 to 46
Re: 2002 grand prix gtp fuel pressure
is this key on engine off, or while the engine is running?
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
its while the engine is running
your fuel pressure is fine.
What does the fuel pressure read at fuel pump prime? That is with ignition to ON only without engine running. It should be in a range of 48-55 psi.
when i hit a hill with the pedal down i have no problem. but when i am on a hill maintaining speed it kinda surges, like a light tugging. but if u give it gas its fine. any suggestions?
How old are the plugs & wires?
And if new, what brand?
Also what is the condition of the MAF air straightener screen in your throttle body?
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
the plugs are two weeks old and are the ngk iridium plugs. i had the same prob before changing the plugs. the wires are about four months old. they are ac delco
the screen also seems fine
