Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 04-21-2010, 04:57 PM
tlclimo1 tlclimo1 is offline
Catilytic Converter 1998
Can clogged cat converters cause engine to go into "limp mode" if they get hot enough? Recently, I experienced engine going under power after 98 TC had been running for a couple of hours. Car would run choppy as in limp mode, but after it cooled, it runs great. Is this common? Can it be possible the 02 sensors got hot and caused this?
Old 04-21-2010, 06:32 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: Catilytic Converter 1998
Clogged cats should cause issues when cold or hot. You may have a faulty sensor somewhere. If you have access to a code reader, use it. There may be a code stored without the CEL being lit.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 04-21-2010, 08:57 PM
Yes, I hooked diagnostics up and it was showing bad on right bank. I just didn't know if that could cause "limp mode" or choppy running, only when hot. Thank you.
