Old 04-20-2010, 12:06 PM
rjinmt rjinmt is offline
93 ford F 150 5.0
I have a 93 nfors f150. We had problems with several a4od we went through 3 trannys. I do a lot of towing. so we decided to convert it to a manual a T18 tranny. During the tear down we found a wire that was touching metal that was making the truck kick into OD when we didn't put it in. So we just finished the convert. Well now we have a new problem the clutch won't engage. it feels like it is almost there but won't fully release. We put a pry bar behind the clutch fork and tried to see if it was the slave that just wasn't working but the clutch fork doesn't want to go any further. This has been a night mare for us but we are so close we just want to get it done.
Old 04-20-2010, 12:51 PM
jyount jyount is offline
Re: 93 ford F 150 5.0
a t18 is that a tremec? the trannies that come out of it are mazda zf transmissions. Sure you have the right flywheel and pressure plate? Maybe there is not enough room in the bell housing for the setup. If it worked ever though, maybe the pressure plate is messed up.
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
Old 04-20-2010, 02:43 PM
it is a borg warner and it came out of a running/ ok rolled bronco could it be a throw out bearing not set right?
