Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 04-20-2010, 08:34 AM
jdfleury6 jdfleury6 is offline
Electrical Issue for 1997 Saturn SW2
Hi there. So I bought this 1997 Saturn SW2 that had its engine replaced. I think they wired it wrong when they did it. They only way to start it is to disconnect the battery then reconnect it. If you don't and just shut it off with the key and wait a minute, when you turn the key to the on position, the instrument panel will not come back on without disconnecting the battery. However, if you start the car and then shut it off, then turn the key right back on (less than a minute) you can start the car without disconnecting the battery. It’s like something needs to be reset once you shut the car off and leave it off for a while. Any ideas?
Old 04-20-2010, 01:20 PM
dcc81187 dcc81187 is offline
Re: Electrical Issue for 1997 Saturn SW2
try cleaning the battery connections and the ground
Old 04-20-2010, 02:16 PM
Cat Fuzz Cat Fuzz is offline
+1. The side post batteries can be deceiving. You sometimes can be fooled into thinking you have a good connection when you don't. Double check that the battery connections are making good contact. Just because the bolt is tight doesn't mean it's getting good connection.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Old 03-03-2011, 04:48 PM
pfuzy pfuzy is offline
I have one of these cars and it has a situation with the anti-theft system. If I lock the car with remote key fob and then unlock the car with a key, it won't start. Key turns in ignition, but no juice, like battery is dead. Battery tests good. Jump start works right away. However, I finally discovered that using remote to lock and unlock the doors fixes the problem! Seems that anti-theft is triggered.
Try that if you have remote. If not, try jumping with good battery. I'll bet it works.
