Go Back   Automotive Forums Car Chat > Buick > Century
Old 04-19-2010, 12:51 PM
know-a-little2 know-a-little2 is offline
Tips on how to install K&N Air Filter ?
Hi - I'm Rob; new to the forum.
I'll get right to the point. I need your help.
Have an 88 Buick Estate Wagon 3.8L SFI ...
trying to install an new Round type K&N 0870 Air Filter but finding no access to get the Air Cleaner top off.
Are there access point(s), screws, clips on the air cleaner housing that are hidden from view?
So far I've been able to loosen & pull the MAF tube to the side - that's all. So no new K&N filter install.
So far Web and library searches have not been real helpful.
thanks in advance,
Rob
Yes I've ordered a repair manual ....
Hobbyist & Restorer
Owned a few GM vehicles:
'63 Corvair 110 Coupe
'68 Impala Coupe
'71 Vega Wagon dog
'66 Chevy C10 327
'81 Buick Century 307
'86 Caprice Classic 305
'88 Buick Century Wagon 3.8L SFI
Old 04-22-2010, 09:00 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Tips on how to install K&N Air Filter ?
wlecome to AF.
1st off, K&N replacement drop in air filters are useless in my opinion. The factory filter and airbox flow exceeds the CFM draw of your engine, so any supposed flow increase is theoretical, and your engine cannot take advantage of it. On top of that, those cotton gauze filters allow more contaminants into your engine, they just don't trap dirt as well.
That being said, to get to your air filter, remove the 90 degree bent tube that connects the air box to the MAF sensor housing. At the top of your airbox, you should now see a wing nut that holds the cover of the airbox to the base. Remove the wing-nut and the top half of the airbox should come off (there is a seal in there so it may need a little prying if it's stuck together) and voila', there is the air filter.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 04-22-2010, 01:01 PM
Originally Posted by richtazz View Post
wlecome to AF.
You're probably correct about contaminants - perhaps that why others say the K&Ns flow better 'cause they don't trap the nasty stuff. My new K & N will have to sit on the shelf until I get the filter resold. Thanks for your input and tips on the housing procedure.
RJ
Hobbyist & Restorer
'68 Impala Coupe
'71 Vega Wagon dog
'66 Chevy C10 327
Old 04-23-2010, 11:28 AM
richtazz's Avatar
you're very welcome.
