Old 04-19-2010, 12:14 PM
jeranamo jeranamo is offline
Thread lock on head bolts?
Do I need to put thread lock on these new head bolts before putting them in? 3.1L
Old 04-19-2010, 01:53 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Thread lock on head bolts?
No thread lock is needed. A thin (very thin) coat of oil isn't bad idea to help lubricate the threads as there being torqued. A little thread lock on the lower intake bolts is a good idea,
Old 04-19-2010, 02:18 PM
Thanks for the reply. I went ahead and put a little of the white sealant on them anyway as instructed by GM.
Old 04-19-2010, 03:27 PM
kevinb70 kevinb70 is offline
Send a message via AIM to kevinb70 Send a message via Yahoo to kevinb70
probably too late, but realize only the bottom 3/4" of the threads are actually used. you wont need antiseize/loctite on most of the bolt threads
long head bolts up top, short bolts on bottom ... if you got the fel-pro kit, that bolt threaded on top is unused. that funny looking stud goes on right next to the water pump (probably obvious) so the bracket can fit on top.
on the head bolts, i used anti-seize... motor oil below the bolt head where it touches the head - this reduces friction which throws off the torque reading.
intake bolts, loctite blue... careful on the hole threads, actually be careful on ANY aluminum threads... very weak.
put a TAD of Black RTV on the "tabs" of the head bolt gasket... these sort of mate up with the lower intake. just enough to seal above and below the tab that sticks out.
TEST COMPRESSION before putting on the lower intake
Old 04-19-2010, 06:59 PM
with or without spark plugs installed?
Old 04-19-2010, 07:51 PM
maxwedge maxwedge is offline
A990 racer
Can't test compression with the plugs in, no?
Old 04-19-2010, 08:18 PM
I've just heard of people leaving 5 plugs in with the 1 cylinder being tested being the only one removed. Wasn't sure which would give me the most accurate reading.
Old 04-20-2010, 07:34 AM
all plugs out so the engine can rotate freely
