Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-18-2010, 01:21 PM
DJShyn3 DJShyn3 is offline
widest tire I can fit on caprice 91 sedan? please help
Hello again
I have a 16x8 wheel and I want to buy some tires for it, but I want to give it a wide mean look, so I am looking for the widest that would fit in those wheels without rubbing my rear wheel fender, because caprice 91 has that fender that comes half way in the rear.
I was thinking on the following:
- 245/55/16 for fronts and 255/55/16 for rear
or
- 245/50/16 for fronts and 255/50/16 for rear
How does the above 2 sound?
thanks
Old 04-19-2010, 11:38 PM
Re: widest tire I can fit on caprice 91 sedan? please help
i really need an answer because i might be buying this online. so if anyone can tell me!!
Old 04-19-2010, 11:48 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
I might be a little off on this, but with the 'skirt' over the rear wheels, the widest I've safely seen used are 235s, and this was tight.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 04-20-2010, 01:24 AM
thanks, you mentioned how you have seen it, so I am guessing you actually have witnessed the 235 on a 91 caprice and there was no room to go any wider? i was hoping to go atleast 245's
Old 04-20-2010, 12:03 PM
silicon212's Avatar
Confoundingly Lucid
Yeah, I pulled a set of 235s off a '92 in a junkyard - had to take the shock bolts off to get the axle to drop far enough to get the tires off. There's not a lot of room in there.
Old 04-20-2010, 12:41 PM
but do you think it matters with wheels? wouldnt some wheels allow you to go wider then others?
Currently I have 205/55/16 on my 16x8 wheels, and I noticed I have atleast 2 and half inch space left between the skirt and tire. what would you estimate I can go with 2 and half inch space?
Old 05-03-2010, 09:32 PM
463's Avatar
463 463 is offline
FYI on my 91 it calls for 225-70-15 on the stock rims. i have now put on 235-75-15 on and they rub on the front if you turn to sharp. in the rear i have to let the air out and fight to get them on and off. the tire is just a punch to big for the car. the speedo is 5.4% slow so when driving 60 mph you are realy going 63.2 mph. thats with the air psi is 32 - 34 psi. http://www.miata.net/garage/tirecalc.html here is the link. looks like 245 will be to wide.
Old 05-03-2010, 11:37 PM
ok but your 75 profile are way too much rubber, so ofcourse it would rub, I am going to go with 55 series in 16" wheel so looking at the stock tire size which is 225/70/15 would be almost equal to 255/55/16 in diameter and width. not much difference, the wheels i have are 16x8 with 205/55/16 and I measured the rear fender skirt and I have about 2 inches space, so I am thinking I could fit in easily 235 even may be 245/55/16
Old 05-05-2010, 12:58 PM
dewaynep dewaynep is offline
The difference between a 225 and 255 tire is almost 1 1/4" in width. That's a big difference in width. You're correct that the diameter isn't much different.
Old 05-05-2010, 04:02 PM
but with the 205/55/16 i have right now there is a 2" space I have in between rear fender and wheel, wouldn't a 255 fit? or 245?
