Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 04-18-2010, 09:59 AM
Panoz26's Avatar
Panoz26 Panoz26 is offline
Dash Panel / Gauge Placement
Would like some opinions, as we all know this board has plenty
I am making a new dash panel and have attached pic's of the initial template and placement - I like the idea of keeping the area for the brake and clutch reservoirs open and in plain sight, but, then again, I also like it closed off...
What do you guys think of just a centered dash panel or should I make one that goes full length to close of reservoirs, computer and fire bottle?
Devin
PS - new motor has shipped and enroute!!
Devin - (aka Panoz26)
Formally WC Car # 26, Red
Now = WC-GT2 # 211, Black
Old 04-18-2010, 10:24 AM
panozracing's Avatar
panozracing panozracing is offline
Re: Dash Panel / Gauge Placement
u sure got a lot of stuff in there. Is that a traqmate and a racepak or some other screen? Lots of gauges too. who has time to watch all that?
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 04-18-2010, 10:47 AM
Panoz26's Avatar
Brian...
the 10" Screen is a rear view camera -- helps me see the spec racer guys..
Traqmate is installed below on the switch panel
Devin
Old 04-18-2010, 01:41 PM
NZGTRA17 NZGTRA17 is offline
Originally Posted by Panoz26 View Post
Brian...
Devin
Devin, not sure why you would want to put a speedo in the prime spot right in front of you. What do you use a speedo for when racing - scaring yourself? I have never raced with one. Only reason I can think of for having one fitted to the car is for monitoring pit lane speed. You can use the tach as a speedo anyway if you know your gearing charts well enough.
I would put tacho where speedo is and possibly flank this with oil pressure one side and water temp the other. That way your 3 prime gauges are right in front of you. The less important gauges can go in the forward position.
Kel.
Kel M
Panoz GTRA #17
New Zealand
Old 04-18-2010, 01:48 PM
Cobrafang Cobrafang is offline
I recommend that you get rid of the switch box and use a Moroso unit. Really cleans the inside look up.
Tom
Brian...
Devin
-Cobra (A.K.A Tom D)
Racer and Gamer
Panoz GTRA (Mystery Chassis #) (Track Toy)
2001 BMW M5 (Road Toy)
2006 F250 (Car Hauler)
2002 Odyssey (Kid Hauler)
Old 04-18-2010, 02:17 PM
Panoz26's Avatar
Tom
Tom, link me..
Kel - if I place the Tach where the speedo is, I can't see it - it's a 5" Tach and once the steering wheel is on, it's hard to see. I mount it to the left on the A-Pillar cage bar (with a shift light).
I like having the speedometer for a quick glance down prior to corner entry and exit - and of course - for top end straight speeds -- that's about the only time I look at it - it's a nice to have, and, I had it, so, I figured, what the heck -- might as well use it.
Now, back to the original reason for my post:
So, after looking at the template for a couple of different times throughout the day today, I am going to close off the entire dash and use 3 pieces of steel, cut a window for my reservoirs -- similar to the Panoz dash that was in there, but a 3 piece for easier removal when/if needed.
If you guys want to see finished project, Ill be glad to post and then apply body armor for the flack that will no doubt follow.
Have a great weekend.
Devin
Old 04-18-2010, 02:27 PM
Panoz26's Avatar
Tom
Tom - DAMN YOU!
I started looking, well, I like.
I can get rid of that entire rig - just need to make sure I can reach the kill switch, etc, if I mount flat panels to the dash plate...
but, you have me thinking now.....
Devin
Old 04-18-2010, 06:18 PM
You can mount it on the top bar at the windshield. passenger side with an angle.
http://www.summitracing.com/parts/MOR-74131/
My dad can shoot you a picture of his....but I warn you.
YOU WILL WANT.
It really looks nice.
Also you can get a multi pair cable like a trailer wiring kit and just run one big cable down the roll cage.
Tom
Tom - DAMN YOU!
Devin
Racer and Gamer
Old 04-18-2010, 07:48 PM
Paul Buxe's Avatar
Paul Buxe Paul Buxe is offline
I just finished mocking up my gauges for my LS2 conversion (while I wait for my custom push rods to show up). I was able to use a 4 gauge panel from Speedway. It uses 4 gauges plus warning lights for each gauge ( I was never watching a gauge when it took a deep six). I was able to mount it on top of the existing Panoz dash. Then there was just enough room to mount the tach to the left of that 4 gauge pack. THat way the tack is right over my right hand on the steering wheel and the rest of the gauges are just to the right. By using Panoz dash as a mount, the gauges are just below the windshield and you dont have to take your eyes off the road much to make a quich look-see. I can pust a picture is anyone cares.
Paul
Paul Buxe
Panoz GTRO-0042 LS2 gone but not forgotten
Miata Chump Car
Mustang GT
Porsche Boxter (wife's ride)
Chev Suburban trailer hauler
Factory 5 Cobra Roadster, 392 stroker
You have to grow older, but you don't have to grow up
Old 04-19-2010, 04:43 PM
feqrags feqrags is offline
Like on one of the other post the trailer connectors, flat 6 or flat 4 work(w/dielectric grease) well, and weather packs are probably overkill- but look nice. You will be proud when removing the pannels..Bill
Old 04-19-2010, 08:11 PM
P_Mac P_Mac is offline
An analog gauge conversion is on my list for this year, so I'd love to see any and all dash conversions.
One question, is it relatively easy to use the wires running to the old Pi dash unit, or would I need to run new wires all the way through the firewall?
Old 04-20-2010, 05:22 PM
Panoz26's Avatar
the only wires I used off the PI were the speedometer wires, everything else was new since the Autometer required different sending units. It's an easy job.
Old 04-23-2010, 07:52 PM
Squerly's Avatar
Squerly Squerly is offline
Brian...
Umm, Devin. There's nobody back there, they're all in front of you...
Squerly
Old 04-25-2010, 12:52 PM
Panoz26's Avatar
Are you saying I am slow or that I am lapping everyone
Old 04-27-2010, 08:03 PM
Panoz26's Avatar
well, I finally got a hold of Brandon -- ending up ordering a couple of GTS Dash Panels.
I had gone to a fabrication shop with my template and they wanted 285.00 to design and laser cut the panel.....
Brandon sold me panels for 33.00 per -- what a friggin deal that is.
Thought some of you might want/need to know.
