Old 04-17-2010, 08:22 PM
gta333 gta333 is offline
S-10 coolant leak
My 2000 S10 truck is leaking coolant right above the transmission. At first I thought it was leaking tranny fluid but it turns out to be coolant. I cant pinpoint the leak. Will took a better look tommorow. has anybody else ever have this happen with them. Thanks Gary
Old 04-17-2010, 08:39 PM
j cAT j cAT is offline
Re: S-10 coolant leak
probably the heatercore or the hoses connecting to the heatercore..
removal of the hoses at engine then pressure test for leak ..
Old 04-18-2010, 08:30 PM
Bills 97 Blazer Bills 97 Blazer is offline
Probably Intake manifold gasket
Old 04-18-2010, 09:15 PM
wouldnt I have coolant mixed with the oil if the intake manifold gasket was bad. that was the problem with the 97 malibu we had and replaced the gasket. Gary
Old 04-19-2010, 07:42 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Depends on what part of it is leaking.
You need to find where it is leaking.
Have a good close look at it and see where it is coming from.
They make a coolant dye to put in coolant for hard to find leaks.
Also a good coolant system pressure test cold and warm and hot will show leaks.
MT
Old 04-21-2010, 07:59 PM
Jrs3800 Jrs3800 is offline
If you have a 2000 S10 with a 4.3 and the Lower intake gaskets have never been replaced, I can promise that the gaskets are shot and are due for replacement.. The good thing is that Fel Pro does make an updated gasket set..
