Old 04-17-2010, 05:01 PM
Firstymer Firstymer is offline
'00 Sepentine Drive Belt Instructions
Can anyone please provide a video demostration or step by step procedure on how to remove and install the serpentine belt on my GP 00'. Its very urgent the belt starts to show sign of wear.
Old 04-17-2010, 05:20 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: serpentine belt diagram
Your post has been moved to its own thread. We prefer not to mix or convolute threads concerning '04 and up GPs with '97-'03 GPs.
Timeslip 08/12/06
AF Community Guidelines
Old 04-17-2010, 07:34 PM
CrazyHorst CrazyHorst is offline
Re: '00 Sepentine Drive Belt Instructions
im guessing you have an L36 - should just use a 15mm or 16mm OE wrench - attach this to the center bolt on the tensioner arm pulley. Using the wrench torque to overcome the moment or "clock" spring then slip the belt off any pulley. There should be a label/sticker on the upper radiator support (crossmember) which is a schematic on how to put it back.
The only tip I have are the belt needs to be seated in all the grooves on every pulley. There isn't that much slack available when the tensioner arm is fully stroked out, so be prepared to work hard on the wrench too. It may be advisable to have a helper to hold the wrench if its your first time that way you have both hands free.
1988 Chevy R-30 1 ton DRW pickup (217k)
1991 Chevy S-10 4WD pickup (192k)
2000 Grand Prix GTP (218k)
2002 GMC Yukon (185k)
2009 G8 - GT (46k)
Old 04-18-2010, 06:41 AM
BNaylor's Avatar
It is best to use the right tools for the job. Use at least a 3/8" drive breaker bar tool/handle long enough to overcome the force of the tensioner which makes the job easier.
For belt diagram which engine do you have? The 3.8 N/A, 3.8 supercharged or 3.1? Post to clarify. From your past posts most likely the 3.1 V6 so disregard any replies on the 3.8 a.k.a. L36 or L67 since it is not applicable or irrelevant. The 3.1 uses a different tensioner system and has a different accessory belt routing.
Timeslip 08/12/06
Old 04-22-2010, 04:41 PM
Question Re: '00 Sepentine Drive Belt Instructions
Yes, Its a 3.1L V6. Is there any step by step diagram or illustration for removing and then installing a drive belt. Please help!
Old 04-23-2010, 08:40 AM
BNaylor's Avatar
See link below posted by Moderator Xeroinfinity (JC) at the Grand Am Tips & Maintenance forum.
Note: Just skip the part with the motor mount in the way and use your belt routing guide.
Click here
Timeslip 08/12/06
Old 04-23-2010, 11:52 AM
Smile Re: '00 Sepentine Drive Belt Instructions
Thanks Bob! That is a great illustration. I have some question, is there any specifics on torque lbs on tightening the tension bolt? Or do I simply tighten the bolt as hard as I can? What kind of drive belt to buy?
Old 04-23-2010, 12:02 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
The tensioner is spring loaded, so unless you are replacing the tensioner assembly as well as the belt, there is no torque value. You just release the tensioner once the new belt is routed and it maintains the correct tension. I would suggest a Good-Year gatorback belt as a first choice.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
