Old 04-17-2010, 05:16 PM
jim2006193 jim2006193 is offline
'97 Grand AM Cooling Fan Not Working Correctly
Seems that my cooling fan will not kick into low when the car starts to warm up.
When it comes close to overheating the fan will kick on high. I have replaced the temp sensor and the fan motor. The relay was check and that did not solve the problem. I have a thormostat that I am going to change tomorrow. Just wonder if there is something I am looking over. Oh, and I checked the fuse also, its ok. Oh, engine is the 3.1 btw.
Old 04-17-2010, 11:24 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: '97 Grand AM Cooling Fan Not Working Correctly
I only see one cooling fan and one relay in the wiring diagrams which indicates there is one fan speed not two. GM's generally don't kick the cooling fan on until the coolant temp gets pretty high. I would be more interested to see what the coolant temp is on a scan tool before I did anything. There may be nothing wrong with the cooling system but the gauge might be going bad giving inaccurate readings.
Old 04-18-2010, 11:32 AM
It just seems to be running hotter than normal just driving through town. I could have sworn that the fan used to run low, but I guess not. I'm going to change that thermostat later today, I'll let you know if that helps. Thank you by the way!
Old 04-18-2010, 03:52 PM
Flushing the coolant tomorrow and changing the thermostat.
Old 04-19-2010, 04:45 PM
K. We replaced the thermostat and it still seems that the coolant system won't pressurize. We used a tool that does pressurize it and it held. Any ideas? He thinks that the pump is ok, but still a possibility that it isn't pumping "enough". Ideas?
Old 04-19-2010, 07:17 PM
Well, its was a bad radiator cap. All is well now.
