Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-17-2010, 03:46 PM
Turbo_Fishtail Turbo_Fishtail is offline
Engine Change
I need some help in regards to my '98 Eclipse GSX. The engine Blew while I was driving down the road. I just figured that if I tried to fix it I'd probably be spending alot more than if i just bought a new engine. I want to put the '98 Mitsubishi 3000GT V6 VR-4 Turbo engine in the Eclipse instead. Is it a good idea? or should I look for a different engine? or should I just keep the engine I already have and spend around $2500 to fix it?
Last edited by Turbo_Fishtail; 04-17-2010 at 04:17 PM. Reason: I edited it because the questions I had asked before might seem unclear.
Old 04-17-2010, 10:44 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Engine Change
You can't put the v6 motor in your car. To many issues with fitment, fabrication. Etc. Yes it is possibly to do the swap but not worth it. The 4g63 is a great motor so keep it in there
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 04-19-2010, 07:05 AM
Re: Engine Change
Well... if I'm willing to go through anything so I can put the 3000GT engine in the Eclipse should i still do it?
Old 04-19-2010, 09:06 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Engine Change
Thread moved from Members Projects.
Ahh... engine swaps....
Anything is possible with time, money and talent. Want to try it, then go for it.
The ONLY motor that is a direct swap for your car is another 4g63. Basic rebuilds cost about a grand to do. Performance rebuilds can go up in price from there. Buying a used working motor is about $600.
Dropping an entirely different motor that has nothing to do with the car, you'll be looking at at least $5,000. You will need the motor, the trans, trasnfer case, ECU, wiring harness, have to rewire everything, custom driveshaft.... then you have to make it fit, do all new mounts, move everything around...
If you want to do it go for it. It won't be easy nor cheap.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 04-19-2010, 05:12 PM
Re: Engine Change
well i have money because i've been saving up, and I dropped a 3.8 L V6 Essex in my Ford Escort Zx2, so wouldn't it be the same concept?
Old 04-19-2010, 11:07 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Re: Engine Change
I would start researching 4g63T engines along with larger turbos so you realize how relatively cheap you can make 400hp. Or you can spend the same amount on doing a complete engine swap which will most likely give you problems in the near future.
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 04-20-2010, 07:49 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Re: Engine Change
I saw a NT 3kGT motor dropped into a 1g, but I haven't seen a TT motor go in. Save yourself the trouble and build a 4g. The weight alone would steer me away.
Kris
2012 Genesis Coupe 2.0t
Old 04-20-2010, 06:12 PM
Re: Engine Change
this is good because i was going for something around 300+ horsepower
Old 04-21-2010, 06:53 AM
Re: Engine Change
With a maintained car and a thought out mod process, this is a cakewalk for the 4g. They came with ~200 at the crank.
Kris
Old 04-23-2010, 12:44 AM
16G_dsm 16G_dsm is offline
Re: Engine Change
u want 300+ hp hes a mod list my friend had on his 96 gsx
stock internals- free
650 cc inj.- $ 120
mhi big 16g turbo from punishment racing- $750
punishment racing fmic- $450
wall 255 high pressure fp- $95
aeromotive fpr- $119
aeromotive fuel rail- $ 120
brian crower 272 cams- $400
custom intake pipe- $30
hks intake filter- $60
boost controller-$30
total- $2174
probally cheaper in your case if you live in the u.s. i live in canada so shipping killed him but when he dynoed his car he was more than happy, 384awhp to the ground
Old 04-23-2010, 07:14 AM
Re: Engine Change
Critical missing items: Engine management/logging and WB.
Kris
Old 04-23-2010, 03:18 PM
ned032002's Avatar
ned032002 ned032002 is offline
Re: Engine Change
I'd like to know where he bought a aeromotive afpr for only $119? I'm just busting your balls.
Old 04-23-2010, 03:45 PM
Re: Engine Change
the afpr was bought off a friend and the car already had dsm link v2 in it so i never included that or the wb lol they came with purchase of car lol
Old 04-23-2010, 05:54 PM
ned032002's Avatar
Re: Engine Change
Nice nice.
Old 04-23-2010, 06:46 PM
Re: Engine Change
ya his gsx was fast as hell lol, we could play with a twin turbo c6 vette light to light cause of the vettes lag and ridiculous low rpm torque lol. but when it came to high way pulls we could only keep up till half way through 4th gear ( vette spins its ass off ) and after that we became a red dot in his mirror
Tags
3000gt , eclipse , turbocharged , vr-4
